235 johnson powerhead
tbirdkidd
I have a overheated and scored powerhead from my 235 hp 1984 johnson (2nd time) are there anyother compatable powerheads that will bolt on to my outdrive like the 225hp
emdsapmgr
Re: 235 johnson powerhead
You are pretty much stuck with the 235 powerhead unless you change the midsection exhaust adapter. Currently yours is setup for any bubble back 235 engine. The loopers won't fit nor will the flatback crossflows. Likely you can find a 150/175/200 crossflow midsection adapter in a salvage yard and swap it out. Once changed, you would be able to use any of these crossflow flatback engines. These flatbacks were made by the thousands and used/rebuilt engines are more plentiful than the 235 version. If you swap for a flatback crossflow, all of your components will work, like the ignition system, starter, etc. The 235's used the larger 1 3/8" carbs which may be too much fuel/airflow for the flatbacks. I'd look to get the specific matched set of carbs with any new powerhead to save time fiddling trying to make the big-throat carbs work. You did not say what year this is, so check the exhaust cover on any replacement block. You may need the special holes for mounting the later model power trim box.
tbirdkidd
actually I pulled it apart and the block itself is not bad 1984 very light scoring but the heads are burnt on number 1 and number 4 so bad they look like raw cast iron all pitted . can these be swapped out for any other heads I know they are scrap.
emdsapmgr
The 1980 and later 235's were the big bore engines at 160 cubic inches. Yours is one of those, so you are limited to the big bore heads found only on these later 235's. Since you need to replace the one head, you could consider trying to locate a pair of used stock high compression heads from the 80/81 models. 325638/639.
tbirdkidd
Thanks for the help any idea where I could look for these heads and can my pitted heads be welded and reworked
farmercr
Take a picture of the heads. I will be willing to bet that you can use the heads with just a little smoothing up.
HybridMX6
Might be able to machine them true and flat again, but then you would need to find a low comp. head gasket or use double head gaskets, depending on how much they have to take off.
tbirdkidd
The sealing area of the heads shouldn't be hurt. Just clean up the pitted area down in the chamber and put a new set of gaskets on and let her go. Post a picture of the heads.
Not sure how to add a picture
tbirdkidd
tbirdkidd
The heads are flat cant even get a .003 feeler in anywhere but the combustion domed area is pitted
