I need to replace two 1994 OMC Cobra 5.0 which are No Good, I prefer not to remove the Transom Assy or replace with one that requires no modification. Can anyone recommend an alternative drive??
The engines are OMC's(fords) 5.0l
Thank you
Like I mentioned on my first post I would prefer not to change the transon assy or at least find something thats doesn't require major transon modification but a solution that can be used with the existing engines.
I will probably just rebuild the engines, but it all depend if I can find a suitable solution for the drives, Like I mentioned on my first post I would prefer not to change the transon assy or at least find something thats doesn't require major transon modification but a solution that can be used with the existing engines.You mentioned that I probably have Volvo SX drives, so would I be able to replace them with volvo SX (and what years are compatible) or do they have to be OMC ones. this is were I'm abit confused.
Thanks a bunch!
Rick...he has the Volvo drives. It may say OMC on them but they are the Volvo drives.You may be able to replace both your drives with new SEI drives (with adapters) for nearly the same price it'll be to rebuild 1 OMC SX.
You should determine the availability of exhaust manifolds and risers before you rebuild your Ford V-8s though.....exhaust, injection and electronic ignition parts for early 90's OMC stuff is becoming increasingly harder and more expensive to find.....
Cheers,
Rick
But then that'll mean you can buy 3 SEI's for the price on one Volvo right?
And the Volvos are worth it!You could get at least six SEI drives for the cost of one Volvo, too bad the SEI conversion kit does not fit this drive.
