Re: No neutral on Ted Williams 7.5 outboard
Thanks for all the help, suggestions, memories, but I will continue my endeavor to get this motor running the way it was designed. My local marine parts supplier, said they have the part (Van?s Marine in Grand Rapids, MI), which when I get the clutch assembly out and decide it needs to be replaced, I?ll follow up on. I have been in boats for over fifty years, and do know how to pull and go, and aim to the sea, but that is not the problem. It?s coming into the haul out dock, in high winds that poses the problem. Judging the speed to reach the dock isn?t always that easy, in high winds, and when I have to shut the motor down, then get blown off my coarse, I end up in the rocks! Where if I had a neutral/forward, I could ease in, much more safely. And, has anyone tried turning the motor around 180 degrees (reverse), while heading down the lake? Good way to get thrown out of the boat! And try to pull the cord with the motor at 180 degrees, one would have to be standing behind the boat and get run over/chopped up in the process!
If all I had to do was shut down and run into a sandy bank, I could live without neutral. That said, I?ll keep you informed.
