Re: Salt water usage?
Depending on how far you go offshore, here are some things you'll need:
- radar (in case your running in pea soup fog or at night)
- GPS and compass (never leave the harbor without a compass, at least)
- SOLAS (safety of life at sea) grade signalling devices, such as hand and ariel flares. USCG rated signals are minimal, at best. SOLAS is superior though more expensive.
- VHF two-way radios for communicating with the US Coast Guard during an emergency. The USCG does not monitor CB radios and cell phones may or may not work well out there, depending on conditions.
- 406 Mhz Epirb emergency locating beacon equipped with GPS. If it is a matter of life and limb and you end up in the water, 406 Epirbs may be your only salvation. If you can afford to upgrade to a 30 or 35 footer, then you can at least afford to get a personnal 406 epirb.
- 7X50 binoculars. Good for spotting distant objects/vessels. Not too small and not too large, I believe this is the preferred size/magnification by a lot of private boaters due to minimal shake and better clarity. One equipped with compass and reticle would be nice, but is not necessary. Some very nice ones are gyro-stabilized and are useful in choppy seas, although these tend to run close to and over one thousand bones!
- First aid kit and freshwater
