Friscoboater
Thread starter- Joined
- Jul 3, 2009
- 3,095
Re: 81 Glastron SX-190 Transom and Engine- PICS Galore Update 11-8
They suggest three coats of epoxy over the whole transom first, scuffing it up in between each coat. If you plan on installing it this upcoming weekend I would start coating it every night when you get home from work. Then PL it in to the boat after a final scuff on the side that will be glued to the fiberglass skin. Then you glass over the whole transom when it is in the boat. Get a bunch of clamps to hold it in. I found a West System user guide which gives you kind of a layout for coating and glassing using epoxy at a local boat part supplier. Start coating that transom now as it needs time to dry in between coats and you may need to wash it down with acetone before each coat.
Off topic: How do you like those Samsung tv's? I just got a 52" 500 series and I love it but I know you said that you are a professional.[/QUOTE]
Samsung is a great TV. The real deal is the new LED. We have been selling alot and man do the look good. I have a 52 530 and it looks great.
