another plug story, with a twist...
dave_g
so I'm new here, be nice. I bought my first and only boat about a year and a half ago. It's a 1974 Yarcraft, 50 hp, grubby little thing. But it's mine and I love it.
So I try to be methodical with everything about it, taking my time, checklists, etc. Maybe I got cocky. I was heading out to one of the local lakes a few weeks ago, a little later than I would have liked. Wanted to get a little fishing in before dark. In a hurry. And I forgot the plug. Put the boat in, go park the car and trailer. Walk back, start it up, let it warm up, not paying enough attention. Untie the line, into reverse, and turn around to see about 12 inches of water in the stern. I freak out, back into forward, onto the beach. Climb into the back, stick the plug in, turn the pump on, crisis averted. The water is draining, okay, cool. Start the engine again, back off the beach, but not far enough apparently. Back into forward, hard over to the right to spin around. And of course, I wasn't thinking just yet. Thump, thump, thump. The prop dragged onto the concrete of the ramp.
Alright, shut it off, drifting out into the lake now. Pull the engine up out the water, survey the damage. From that vantage point, it didn't appear to bad, the engine started and ran, so I went fishing. Caught a few fish, went home and took a closer look. The prop was pretty chewed up. I was able to file the worst of the sharp edges out, and it's serviceable now. I just hope the lower unit is okay. It still shifts okay though. Lesson learned. Don't be in such a big hurry!
coolguy147
Re: another plug story, with a twist...
patience is a virtue;)
its been a struggle for me too to be patience about fixing my boat and wanting to go out and get some boating. but i must do everything right the first time and be worry free:D
joed
Props need to be balanced or they will vibrate. It might need to be worked on at a prop shop.
drewmitch44
Sometimes you have to be in a hurry if you are not in a hurry the lake might be gone when you get there and you will have nothing to do but play around with your tie-downs.
Knightgang
Take the prop to a prop shop and at least let them check the balance. It would be worth it to avoid vibration damage in the LU...
Thad
Welcome aboard. You're still here, aren't you?:confused:
Being that your first post is in SHT's, I don't know if I CAN be nice:rolleyes:, just kidding.:p
How many and what kind of fish did you catch? Info man, info!:D
If you were just leaving the ramp/beach area, you should not have had much trottle to her, so your drive gears should be just fine. Your shaft as well. The advantage, and basic premise of an aluminum prop is that it gives first. Absorbing the brunt of the impact. At a low to moderate speed there is usually no damage other than the prop. That baing said, continued use of a damaged prop can and most likely will be catastrophic. Get a new prop, put it on the motor, have the damaged prop reworked and keep it in the boat for a spare.
Go ahead and check your mounting bolts through the transom if you think that it hit hard enough to jar the motor, more of a peace of mind than anything else.
Happy boating and good fishing to you.
DECK SWABBER 58
Welcome aboard Dave. Everyone here is nice, trust me.:D
I can make you feel a lot better. My first 3 post's were to SHT'S. Just do a search of my handle and read First Boat Part 1, 2 & 3!!!!!!!
But now I'm a "experienced" boater and have not had to post any antic's since. BUT, STAY TUNED, next year I will be "cocky" just like you!!!!!:p
