Re: Winterizing Volvo 5.7
From my AQ271 Operator's manual, page 6 item 20...
Quote
COLD WEATHER PRECAUTIONS
Before leaving the boat check that there are no water leaks.
If there is a risk of freezing, drain the cooling water from the engine. The cooling water on the port side and on the starboard side is drained through cocks on the side of the engine block and on the exhaust pipe.
Undo the cover on the sea water pump as well. CAUTION! Close the cocks and tighten the cover before you leave the boat.
If the boat is equipped with a sea **** make sure it is also closed.
End quote
This is all I do for a seasonal layup since it is for 4 months and it is not in the water. This year I am changing the oil also, usually I do that in the spring, just my preference.
There is another section labeled "INHIBITING WHEN LAYING UP FOR THE WINTER", starts at the end of page 12 and has the recommendations you pointed out for when the boat is to be in the water for extended perionds without running, and also a dry land storage procedure for longer layups. It says it is for a seasonal layup but in my opinion it is overkill for the winter season that my boat sees in Kansas.
Now, I will translate the "The cooling water on the port side and on the starboard side is drained through cocks on the side of the engine block and on the exhaust pipe."
There are a total of 4 drain plugs, 2 on the engine and one on each exhaust manifold.
The engine block has two heavy brass drain plugs down low, one on each side, I think a 3/8 pipe fitting size with a 9/16 wrench size hex head. On mine I take the fuel filter off for easier access to that side, HAVE A TOWEL OR SOMETHING IN THE BILGE READY BEFORE THIS! The other side is easy to reach. Remove them and use a stick or small screwdriver or rod to poke up in the hole and make sure all the water can get out as there will be some scale and junk there. There should be a lot of water come out, more like quarts than cups.
There are also drain plugs on the exhaust manifolds, one on each at the back. These are large heavy brass plugs, like a 1 inch hex head size. (Please do not hold me to these wrench sizes!). They will be just barely accessible as they are between the back of the manifold and the Y-pipe tube. Remove them and poke around as best you can to make sure they drain. They are large holes so this is usually not a problem. A pint or so should some out of each manifold. If I see a lot of crud then I remove the front hose for the manifold at the thermostat housing and pour a gallon or so of water in thru a funnel to flush it some.
Also definitely crack the front cover of the raw water pump and let that all drain for a minute or 2 to finish the job. This drains all water from any hoses in front and after this pump and would also take care of the power steering cooler if equipped.
I have been leaving the drain plugs out and stored up on the intake for spring commissioning. I put the fuel filter back on just for a seal as it will be replaced also during spring commissioning. I have also been leaving the cover loose on the raw water pump.
That is my 15 minute winterization. It almost takes longer to remove the seats and engine cover
