no alarm beep prior to start? 89 90hp rude
tony6813
great forum,been searching for this answer but cant find one. here is my problem 89 sea nymph boat with 90hp and vro still working, that has 3 wires coming out of it. 2 overheat sensors in the head that has 1 each.I should have a beep with key in run position, prior to start but I don't. I did ground out the 2 overheat sensors and alarm did sound with key in run spot. Is there a ohms reading for the sensors? I also unplugged the 3 wire plug from vro and did an ohm reading and got 1020ohms across 2 of the 3 wires (grey to black). No reading from(black to tan). I also have 2 wires coming out of the oil reservoir. Is this a float alrarm? why no beep when I turn key to run position??????
Re: no alarm beep prior to start? 89 90hp rude
could have a bad horn, or dirty connections.
tony6813
I did ground out the 2 overheat sensors and alarm did sound with key in run spot. could it be at the key switch?
