62' Lark thermostat ?s
carterkraft
Ok I got the starter straightend out, runs like a top. On to the original problem, not pumping water.
taking a tip from the guys on this board I removed the thermostat housing and no water came out. I replaced a new but deformed impeller, problem solved new one created...
How does the thermostat go back together. the way it was I don't think is correct. The oring was at the bottom, the ball spring was next up followed by the thermostat in the plastic cup.
Does anyone have a pic, or can just tell me with any confidence.
Thanks you guys.
bktheking
Re: 62' Lark thermostat ?s
This should do it for you.
carterkraft
Thanks a ton for that. The seal #32 had me baffled because it was part way down the passage under the thermostat when I pulled it apart.
Thanks again.
