Need water pump for 1962 5.5 johnson seahorse CD-19 S.
ugotstyle
The bottom piece of the water pump (cone area) is totally corroded and has started to fall apart in pieces. I need to know where I can get a replacement of the whole system and a price. Can anyone refer me?
Oh, the previous post was asking why there's a broken piece under my water pump, now I know why!! it's the bottom half! :)
F_R
Re: Need water pump for 1962 5.5 johnson seahorse CD-19 S.
The part below the water pump plate is called a bearing housing, part number 376074, replaced by 382796 (very $$$$). The gasket is 303339.
Those parts are not part of the water pump. If you are looking for a complete water pump kit, the origional pump is obsolete and is replaced by 763758. The new one (763758) is very different than the origional and will update the pump to the kind used in newer motors of the late 1970's -up. As I just mentioned, the pump kit does NOT include the bearing housing. You have to order both.
All this stuff is available from an Evinrude dealer.
gwatsurfer
I have a completly good running 5-1/2 Johnson CD-19-s runs fine I will let it go make me an offer.
