jharvey1984
Thread starter- Joined
- Oct 17, 2009
- 33
Hi. I am new to boating and iboats. I recently purchased my first boat (98 four winns) with a volvo 4.3 gl carbureted (engine number 432BPBYC) engine and sx drive. The last time I took it out I could not get it to start on the trailer. Discovered the fuel pump is not working. I jumped the pump directly from the battery and it works fine so pump is OK. I replaced the relay and checked the breaker... still no luck. From searching on the forums I have learned that power to the pump is provided from the starter during starting and the alternator during normal run. My question is what should I do next? Should I jump the pump to get it started and then unjump it to see if it continues to run? If so then that would narrow it down to the starter, right? If not then would that give me any useful information? Thanks in advance for any advice.
Jimmy
Jimmy
