timfives
Thread starter- Joined
- Jul 30, 2009
- 382
All-
Late spring i bought a 91 Starcraft islander for cheap. That should have been my first clue. However the 3.0 runs like a top (aside from the need of a carb rebuild) but the boat is exactly what i wanted. I figured i'm pretty handy so i should be able to do most of the work.
Basically i'm gutting the interior and reflooring, and redoing everything.
As i'm getting started i do have some questions, and looking for some suggestions.
1. What is the best way to remove the foam under the floors. Looking for your tips and tricks for removing the stuff.
2. Flotation: what is the best closed cell flotation?
3. What do people use to replace the decking 1/2 inch or 3/4?
4. I've got epoxy to seal the wood, how do most people finish it?
5. Transom, I've got a little rot in the transom, I won't know the extent until i get all of the foam out etc. i've seen many people just replace it, or fix it with git-rot. My initial thought was to just replace, but the mech's at the marina indicate removing the engine and outdrive is a huge job, and that putting it all back together requires a special alignment tools?? I'm not sure i can even get the engine out but assuming i can, do you need special alignment tools?
6. refinishing the cuddy. Anybody have any pics or posts on this? Anyone know where to get new cushions??
I appreciate everyones two cents, this forum is great, and is one of the reasons i figure i can successfully complete this project.
Thanks so much for your thoughts and suggestions, I'll be posting pictures soon of this project.
Tim
Tim
