I want to make a bigger swim platform this winter for the boat. It will be 8 feet wide by 36 inches long. From the center of the platform to the edge it will drop 1/8th of an inch in 4 feet. I want this for water drainage. I'm going to use west system epoxy to seal the 3/4 inch plywood. I'll be using 2 peices of 3/4 plywood glued together. I can a temp frame to hold the platform in place. If i just fiberglass the top section first. When i remove the clamps will it retain the slight curve yet?
