Carb Interchange
yorab
Ensign
Will a carb from a 1971 75hp Johnson fit onto a 1963 75hp Starflite? It looks like it will just by looking at the pics, but I can't be certain.
Re: Carb Interchange
The '63 motor had a single 2 BBL downdraft carb. Did the '71 also have this style? I would have thought they would have changed to a side draft carb by then.
Faztbullet
They didnt make a 75hp in 1971, the V-4 75hp was from 1960-1964/65 and didnt reappear till 1975/76 then as a 3 cylinder. Are you sure it not a 85hp carb, as the 1966-68 85hp had the same 2 barrel down draft carb?
yorab
Ensign
Yeah, it's definitely the two bbl downdraft with water choke and fixed high speed. Looks identical to the '63, but I can't see the mating surface from the pics so I don't know it it will mate up. The guy selling it tells me it's from a '71 Johnson. I'll email him again to let him know that the year must be wrong.
R.Johnson
The easly double barrel, down draft carb is nothing like the later single barrel carb. They certainly will not interchange.
