CABASSFISHER
- Joined
- Oct 22, 2009
- 1
i recently was out on the lake full power on plane when my alarm started to sound and Beep beep beep beep etc.....I then powered down and did a little survey realizing my 2 cycle oil tank was low.......not sure if this was the problem, it still had say 1/4 or less oil in the tank, but not empty......i filled up the tank with all the oil i had available which now put it to 1/2.....the alarm is still beep beep beep beeping....i gently drove back to dock and trailered boat home,.....after i got it there i hooked up the water flush kit started the motor to see if there was any change in alarm....it then seemed to go to an even higher pitch beep beep beep.....im now writing this to get some input if any ones got any....thanx
