While winterizing my 90 hp evinrude (ficht), the engine sputtered a bit and I went to shut it down, but it would not stop after I had turned off the ignition and pulled the key out. While the engine was still running, I put the key back in and turned it and the warning light sequence came back just fine. After trying to shut it down with the key a few times it still didn't shut down. I unhooked the fuel line and let it run out (very surprisingly, it ran for just over 33 minutes without a fuel line hooked up).
Any ideas on where the problem may be?
thanks
thanks
