oh2fl
Thread starter- Joined
- Sep 10, 2009
- 11
'99 SeaRay 180 BR, 3.0, Alpha 1 - what else?
unknown hours, etc. Looks great and starts runs nice.
I saw the dealer flushing the rear drain hole when we were about to pick it up, having some oily substance in the mixture. 'Oh, so spillage'. ... Everything checked out okay and we bought it ('as-is).
(So forget the dealer is what I mean).
When we took her home, dropped in the fresh water lake (Ida) & motored on home to our canal lift. Renting this home (so modifications.... not really) which has a front pivot lift (for lack of better description).
When the boat is up out of the water, the rear is 2-3 feet above the front.
*** I don't own a truck, so it can't be pulled out of the water unless I go rent one or borrow someones***
I smelled something, and then found in the ski storage in the floor; oil/water had come in from the engine area through a tube with a missing plug ... ggrr -
(*Bonus Q? - what size is this plug?).
The oil looks and smells like 90wt rear gear oil.
Engine oil is golden, clean and full. Lower unit reservoir is at the original level, no leaking.
The TRIM motor goes down but at the switch, it doesn't come up or make a noise. Using the TRAILER button, the OB trims up well.
I noticed the trim reservoir cap looked oily so checking this, near the battery on the starboard side, the fluid looked milky.
I don't have a book on the boat yet, but what type of lube is used in the trim system/reservoir?
