Yamaha 15hp is pulling air on the fuel stroke
starett
"I brought my Yamaha 15mshv 2 stroke to the repair shop after I failed to repair my problem of not being able to start it. I did go through all the usel steps of cleaning carb replacing plugs new fuel check spark. There diagnoses was that on the draw stroke air is getting by the crank seal not allowing the draw stroke to pull fuel? Has anyone experienced this before or should i be looking at something else
moonfish
Re: Yamaha 15hp is pulling air on the fuel stroke
You have a compression tester you can use? They're cheap and they will tell you what you want to know. You could pull the spark plug and put your thumb over the hole and when you turn the motor over it should push your thumb off with the pressure and both cylinders should act the same.
Why didn't the mechanics fix the problem? If they think it's the seal, why didn't they get the seal and fix it?
The FAQs here are awesome
starett
The comprssion on both cylenders 125 psi the macanic explained to me that the motor needed to be sent to a machine shop to deal with the crank shaft pressing the pistons back on the shaft? Not quite sure if im not getting the shaft! seems to me the problum would be at the reeds?
sigma
What year is your motor? I want to look it up to give you some more info
starett
The motor is A 1997 15mshv.the macanic explained that the motor ran great when air was forced into carb at idel or runs at half throttle with out any help
but wont idel on its one
moonfish
S, explain the problem more. You have it running, but it won't idle? Or what? Explain it all out.
starett
here is some history on the motor.originaly there was water in the lower clynder,replaced head gasket.went through the carb and replaced fuel pump diaframs,reed valves check OK.now the motor is hard to start once started it will only run at 1/2 (1500rpm)throtle and not able to gear it.But if you idel down it dyes,wont pull fuel from carb only if it is forced with air behind the fuel.This also has me very confused.only thing i can figure is on the intake stroke its pulling air insted of fuel from somewhere
moonfish
That's easily possible. Put some premixed gas in a squirt bottle and feed it some gas, start it and see if you can keep it running that way.
Also, another thread had the idea to put in some clear fuel line temporarily so you can see if there are bubbles in the gas, there shouldn't be but if it's leaking, you'll see them. I think most of my motor running troubles have been gas line leaks.
You can also unhook the fuel line after the fuel pump and turn it over and see if it's pumping. Hook some clear hose on there and it'll be easy to see.
Gas lines can be bad anywhere, in the motor, any connector, even in the gas tank itself.
You should get the manual for the motor. Diagrams are great and invaluable. You can also have problems if you messed up assembling the carb or there's a gasket missing or something. It happens, and it's all hard to convey over the net.
