too much oil from injector
jjhallowell
The oil injector for my 2000 50HP Johnson pumps so much oil during start up that the engine does not start for a long time and when it dies, it smokes terribly for several minutes. At idle the engine is rough, yet at higher RMP it smooths out. How do i fix this problem short of disconnecting the oil injector?
wilde1j
Re: too much oil from injector
The fix is typically to replace the OMS pump, although some here are fond of getting rid of the oil injection and just mixing the oil yourself in the tank. Sounds like a check valve in the pump on the oil side is hanging open and allowing the float bowls to fill with oil, especially if it clears up after a few minutes run time.
kenmyfam
First sign I got of my VRO failing was it over oiling. You have an OMS pump but it still could be the issue.
R.Johnson
Do you have a fuel restriction? That wii make the pump over oil
jjhallowell
Thanks gentlemen for the info. There is not a fuel restriction.:confused:
R.Johnson
could you give us the fuel pressure & vacuam reading' Then we know were we are at
Air leaks in the gasoline lines will cause over oiling. It will be at all speeds, BTW. Can you determine if the problem is only at idle, or at all speeds?
wilde1j
This is correct also.
jjhallowell
The problem is at start-up. I do not have the ability to measure fuel pressures and vac vacume readings.
R.Johnson
jjhallowell: That is a good reason not to replace, or take thing's apart.
jjhallowell
Yes, I know my level of incompetence with boat engines. I was hoping it might have been solved by an adjustment. From everyone's postings, I believe I'll take it top an engine mechanic .
Thanks
