WadmalawJoe
- Joined
- May 31, 2009
- 32
I just purchased a 2004 Sea Pro 206 cc with a Yamaha 150 4 stroke. The throttle up cable is stiff and sticky. The first inch or so of movement is fine, but to go from 1/4 throttle to wide open takes some muscle. I have sprayed a lubricant on the ends which of course did very little. I am thinking of disconnecting the cable from the motor end, attaching a rubber hose which will be attached to a funnel. In which I will pour a little bit of oil into and let it sit upright for a few hours allowing the oil to seep down in, while I occasionally work the throttle. Sound like a plan? Has anyone else done this or have had luck with something similar?
Thanks!
Thanks!
