Has anyone use bep marine switches
83Evinrude
Re: Has anyone use bep marine switches
I put one in our RV a few years ago to keep its propane detector from running the battery flat during inactivity. It works just fine, ours is just a shut off switch but should be the same quality.
bear_69cuda
I used a BEP VSR set-up in my Bayliner project (link below) I plan on the same set-up in my Hurricane. Great hardware.
amanphoto
bear_69cuda great project.
bear_69cuda
Thanks amanphoto,
Wish I could have kept her...
4JawChuck
I have a BEP cluster in my boat, I have two battery's...one for starting and the other for trolling. They are well made products and worth the extra money, this is the model I have for a dual battery single engine configuration 12VDC setup.
http://www.bepmarine.com/Single-Engine%2C-Two-Battery-Banks-180-1460.html
Make sure you get the right one for your needs though, if you only have two battery's...use this one.
