Wiring diagram wrong? Please take a look at them and see what you think.
blk98gt
Here is the original diagram. I highlighted the area of interest. I don't think the the field tab of the regulator should be grounded and I'm pretty sure the key ignition switch should have a ground.
Here is what I think it should look like. I'm just confused the diagram would be wrong and questioning my logic here.
blk98gt
Re: Wiring diagram wrong? Please take a look at them and see what you think.
I can't believe they would have such a bad mistake in the diagram. Oh well, thank you. BTW, here is my corrected diagram if anyone needs it:
blk98gt
Hey, F R, do you know where the tachometer lead goes to? Seems like it just gets grounded at the box. How does that work?
F_R
Well, lots of luck. It requires a special kind of tachometer designed to work on a magneto. They are no longer made and are getting to be as rare as chicken fangs. Modern motors all use an alternator-driven tach. Your DC generator just won't do that.
If you do find a magneto tach, it connects between the black wire leading to the magneto, and ground.
The other option is a Tiny Tach, which is an induction tach working off a spark plug wire. You be the judge on that option.
