longstand
- Joined
- May 2, 2009
- 293
I have a twin Engine. i have two of everything. my Tilt on both of my engine was working before.
I started remove some intake manifold on both engine and replace some Riser and clean exhaust manifold. that's when this tilt problem start giving me problem.
i have try to put metal on the solenoid on one of the engine for the tilt so i don't have to push the switch, just to test it directly without the switch but still the same result. all i hear is click.. so i replace the motor and install it with the proper gasket... i have install the ground, i even grind the metal so it will be shiny.. still the same.. so i remove the TILT system and SOKE the clutch in ACETONE. and install it after cleaning.. still the same... i check the ground from the engine to the battery. even grind the battery terminal shiny for good contact. still the same... i remove all the wire from the started where all the wiring lead to some solenoid and grind it shiny. still the same.. i have check the fuse under the dashboard. still the same..
above mention is for the #2 engine.. but the #1 engine is doing the same thing. but this time. the TRIM will not work... i Did not put no metal object to any of the solenoid on this #1 engine. #1 just click on the TILT. but working on the TRIM..
I need serious advice. i cant seem to get this to work.. i read the boat many times .. iam thinking iam only having electrical problem but iam lost of where to start now. i have try all i could...
question: Clutch on the TILT. does any of the CLUTCH parts move.. because my seems to be STACK together....?? also when the clutch is remove from the housing.. will the WORM GEAR be able to move ? because my is not moving...
