225 Evinrude V6 VRO 1988
cbdv
Engine stopped while running. Fuel is going through the VRO pump, but when turning over it sounds like it is not gtting fuel. I checked the spark plug wires when turning the engine over and there is no electric flowing from the wires (I checked 2, one on each side). The engine started right up and ran perfect prior to this incident.
Re: 225 Evinrude V6 VRO 1988
check with a spark tester, all 6 cylinders. it sounds like the power pack has failed.
jonesg
The other obvious is the kill switch and its wiring.
Faztbullet
Take a ohm meter and check the timer base & stator readings as this will tell you if you have a bad pack.
