Flywheel help
wakeboarder3993
i recently boat a used boat.
1999 bayliner 1850 with mer-cruiser 4.3 v6.
it started to have a starting problem.
took out the starter.
the fly wheel is missing two teeth and the starter doesnt catch.
could some one tell me if i could get a starter out of a chevy astro or blazer since they have the 4.3 or are the number of teeth different
i looked it up theres a 153t and a 168t (i think)
what flywheel is used for boats.
and if i have to replace the fly wheel
will i have to pull the motor or be able to remove the stern drive.
help help help
the guy i bought it from said he replaced the starter with the automotive one for a 4.3 v6 thinking it wouldnt make a difference. could that have cause the missing teeth
Re: Flywheel help
Ayuh,... Welcome Aboard...
Automotive starters are an electrical No- No in boats,.. You need a Marine rated starter..
It's determined by the Starter,...
Straight across bolt pattern is the 12" flywheel...
The Staggered bolt pattern is the 14" flywheel...
You don't need a Flywheel,.... You need it's Ring Gear... About $50. or less at Napa...
Yes, the Motor has to come Out,... The drive has to come off to get the motor out....
wakeboarder3993
Re: Flywheel help
Thank you it was a lot of help. 20 dollars from napa
