Anyone own a searay SRV190, I need the weight
Fordiesel69
I weighed mine today with a total of 2500 pounds. I have not yet subtracted for the battery or the fuel. I already weighed the trailer so I subtracted that.
I need a spec of dry weight, or if you had yours weighed. BTW I have the 4cyl 120 HP power plant.
Fordiesel69
Re: Anyone own a searay SRV190, I need the weight
Anyone else own one of these?
Could someone try the searay website, it will not come up for me.
kregars
NADA says 1,400lbs. which I do not believe. See for yourself:
http://www.nadaguides.com/default.aspx?l=1048&w=24&p=38&f=5692&gc=MR&gtc=MR&ml=S&pg=2
Our son has a 192 Ebbtide BR with Mercruiser 4.3LX GENII and it weighs 2,600lbs. dry which I do believe from towing it for 300+ miles.
SeaRay's warranty department should be able to tell you the OEM specs.
Is it possible that that is the hull weight only? I know for the Proline series boats, the weight listed in NADA is dead on when you subtract the weight of the engine(s) be they I/O or OB. For instance, for my 260WA it states 3200 lbs (No engines, water, fuel, oil). Then you have to find the weight of the engines, and any gear you add to get the correct weight.
Scott
