I have a '62 14ft. BlueStar. I've been running a 5hp Briggs for 4 years and finally getting rid of it for something more civilized. Question is the weight difference between the 6hp and 8hp Tohatsu is ~25lbs. Not being a boat guy I'm wondering if the 81lb motor might be too much for my little old aluminum transom? (It does have a wood transom mount on the outside and inside of the transom).
Also the difference is only 2hp but will the 2cyl. setup make the 8 enough smoother running to justify the $400 difference? Thanks in advance!!
