I know I read something here a while back related to this but can't find it now. Did'nt have the problem until today.
1973 135 evinrude, after running alittle under WOT for about 1/2 hour, the engine gradually slowed down, as it did it started knocking very loudly , then died.
On restart try the starter just jammed on the flywheel.
I pulled the cowling and was able to turn the flywheel by hand so I went back and tryed the starter again. It started right up but was still making the knocking, being in the middle of nowhere I put it in gear and started creeping home. I then noticed the knocking was fading away. I gave it alittle more juice and it was fine. When I got near my creek, I opened it up and it was totally normal.
I know I read recently about a coupling under the water pump that, when worn can expand and jam the drive shaft. Could this be my problem?
The only other weird thing that the engine always did was that, again, after running near WOT when brought back down to idle the engine does not fully return to idle speed in neutral, it races slightly and sounds almost like it's having pre-ignition. After a minute it slows to a normal idle.
It is not over heating and from a visual inspection through the sparkplug holes, I see no carbon. Top of piston is clean, I did use a few cans of carbon remover anyway but it made no improvement.
I'm alittle afraid of this thing now because my dad's boat (for rescue) is out of the water. Not many boats on the bay in November.
Any input is welcome,, Thanks
