Big Pete
- Joined
- Aug 12, 2009
- 192
Hi
The engine is running fine but on giving it the once over , as i have only recently brought the thing and got it running..
I noticed this wire problem from the manual i think the box is a rectifier ?? as the yellow wire in the manual shows going to a rectifier ..
Well the previous owner has obviously had a short and fixed it by adding a new orange wire , and just left the 2 wires in there corroded and burnt state.
I have taped the burnt out end with red insulating tape , which you can see on pics.
Now is the rectifier or whatever you guys say the burnt out bit is ? Ok to just tape up and carry on as the engine is still running ok ..
Or should i get new and wire the 2 burnt out wires in again as it should be , BUT !! the question then is what caused it ? The ignition switch is not the original so maybe thats why they have now been left off ?
anyways heres the pics . views and suggestions appreciated
Now looking at the burnt out box .. North position is the new orange wire , South position has the yellow wire , and the 2 burnt out wires one is yellow and the other is like a grey or an off white colour both was on peg at WEST position which is now melted away as per pic.
Advice needed , its running still so i assume its been like this a fair while ?
I have taped the 2 wires in red insulating tape , so you can see what and where they are ..
