boondox813
Thread starter- Joined
- Sep 6, 2009
- 7
hello everyone baught a boat 2-4 months ago been doing some minor engine work (replaced spark plugs,spark plug wires, 3-carb rebuild kits, re-routed the tell tale) took the boat out for the first time yesterday (the boat had been sitting for 3-4 years) the boats is a 15.1' 1987 procraft 1510 with a 1985 Evinrude E70TLCO took the boat out yesterday for the first time . . the boats cranks the first time every time . . smokes a bit but its kinda expected from a two stroke and its not ALOT . . boat runs in-gear but only at idle speed ive noticed the cable linkage from the throttle box to the motor is jacked up pretty bad . . assuming this is the same linkage for the fast idle that is . . . and when i manually give the boat more gas it kinda drowns out and stalls . . im hoping this is just bad calibration of the carburators but for now am at a loss i read a few threads about compression and timing and what not but not 100% confident in mechanical skills of that calibur not to mention i do not believe that that could be the source of my issue . . any help would be appreciated and thank you in advanced
