air0msw@yahoo.com
Thread starter- Joined
- Jul 14, 2005
- 39
I have a 2001 Volvo 5.7. What oil should I be using? My manual says 30W. I can't seem to find that in synthetic. Just curios if I should being using a blend or not.
The duty of a marine engine is different from a cars. Think about it, for how long do you hold 4400RPM on your car? Volvo and Merc figured this stuff out already, I go by their recommendation.I use multi grade oil because there are no Volvo oil sellers here, I like synthetic oils, they are readly available at local retailers and low cost and are used not just in millions of car and truck engines but are also recommened by Merc in their IOs with same blocks as Volvo.
My point is this; why does an engine whose manufacturer (Ford or GM) recommends multi wt and Merc using these same engines as Volvo also approves multi's sudden have to have a single wt that is only available from Volvo just because the engine was shipped once to a Volvo plant?
I guess I don't understand. Are you saying since GM uses "x" oil so should Merc and Volvo?I think you misunderstand my point.
Yea Volvo and Merc should know what is best BUT they both use the SAME blocks so why the big difference in oil specs?
Not a auto/marine issue at all.
Let me get this straight . . . You, yes you, Magster . . . you get a new ride, you hide out in the Manufacturers section to report that, you use her to commute to work which is like mega cool, and then, you flippin' surface for a flippin' oil thread?????? WTF?
Sorry gentlemen, you may now return to your previously scheduled disaster thread![]()
Oh, BTW, Hi Mags . . .![]()
