Johnson 25 Hp
bktheking
Re: Johnson 25 Hp
Gotta love the question, it's more of a statement actually! I'm waiting for this person to post a follow up with the detailed instructions.
Mas
Re: Johnson 25 Hp
A OMC service manual will detail the procedure. You might even be able to check out something from the library.
MAS
mary heller
Re: Johnson 25 Hp
thank you, sorry I guess I could have asked the question better!
Elbo
Re: Johnson 25 Hp
There are 3, 7/16 Bolts on the bracket that holds the starter.One in front one on the side and one at the bottom. The one at the bottom may have a grd wire on it .The one at the bottom may be a little tricky just look for it and you can get it off.very easy.
psteurer
Re: Johnson 25 Hp
That lower bolt holding the starter is a real bear to find. It is way down underneath the starter in the back. Use a flashlight to find it. There is not much room to work with but not too bad to get out. I would recommend getting a manual. There are quite few things to disconnect before you remove the starter.
KoenBrink
Re: Johnson 25 Hp
Are you in the Netherlands? I can tell you a store who does this kind of jobs for free.
