Re: 96'Mercury 2 stroke reed replacement?
Is it leaking when it's running or when it's off? Either way it sounds like the carb need to be rebuilt, some of the seals and gaskets may be bad, when its running all the gas that comes out should be sucked into the engine, when its sitting and it leaks, usually you have bad seals, or the needle isnt fully closed. You shouldnt need reeds, thats when they backfire and you notice stuff like burned fuel or carbon in the carbs, or just running rough.
