scoutabout
Thread starter- Joined
- Oct 14, 2006
- 1,568
Seems like a good time of year to remind everyone who boats in frigid temperatures of the 1-10-1 Rule as well as other critical facts about hypothermia.
From www.coldwaterbootcamp.com
"Dr Gordon Giesbrecht coined the phrase 1-10-1 to describe the three critical phases of cold water immersion. Over many years, Gordon has researched the effects of cold water immersion on hundreds of subjects and has personally experienced those effects himself over 30 times.
1-10-1 is a simple way to remember the first three phases of cold water immersion and the approximate time each phase takes.
1 - Cold Shock. An initial deep and sudden Gasp followed by hyperventilation that can be as much as 600-1000% greater than normal breathing. You must keep your airway clear or run the risk of drowning. Cold Shock will pass in about 1 minute. During that time concentrate on avoiding panic and getting control of your breathing. Wearing a lifejacket during this phase is critically important to keep you afloat and breathing.
10 - Cold Incapacitation. Over approximately the next 10 minutes you will lose the effective use of your fingers, arms and legs for any meaningful movement. Concentrate on self rescue initially, and if that isn?t possible, prepare to have a way to keep your airway clear to wait for self rescue. Swim failure will occur within these critical minutes and if you are in the water without a lifejacket, drowning will likely occur.
1 - HYPOTHERMIA. Even in ice water it could take approximately 1 hour before becoming unconscious due to Hypothermia. If you understand the aspects of hypothermia, techniques of how to delay it, self rescue and calling for help, your chances of survival and rescue will be dramatically increased."
Also, here's a link to an immersion demo performed last year on Lake Muskoka (co-incidentally where I spent most of my formative boating youth). It's a shame about the cheesy music but you can see it doesn't take long for the chattering to start. Air temp was -13 deg C, water I think about 4 deg.
PFDs are smart anytime. Not wearing one around cold water stacks the deck against you considerably.
http://www.cottagelife.com/index.cfm?ci_id=34505
