Eliasarmatas
- Joined
- Oct 24, 2009
- 16
My engine, was not speeding up when i tried to speed faster. I opened the 3 carbs and cleaned them manually. Did not use sprays or any other solvent. Just rubbed them with soft cloth . The lowest carb had a float chamber full of a white thing, and the entrance valve, was stuck open, so when i pumped gasoline inside it came in without stop.
When i cleaned them , i put them back to their position and was hoping that it would run fine. I tried the engine in an barrel with water. It starts but after a few seconds it dies. When it tried to raise the lever, to go faster, it died again. After i did this a few times, the engine would not start at all. I used the emergency start with the red swith , and it start, but when i closed this , it died.
In the middle carb, there is a screw with a spring . This is grooved to the end. It seats completely. I tried to turn it to the left, but it is not possible. Is this supposed to turn? The other 2 similar screws with the spring , turn to the left, and i put them 1, 1/2 turn to the left.
Any idea of anything else i could do?
I also have photos, if there is some way to send them to somebody for help
thanks for any help provided.
