Re: Shift Cable Leaking Water???
You don't specify but it sounds like it is leaking on muffs? Mine was leaking the same way. Either you damaged the water passage o ring or the mounting gasket allowing water pressure to enter the shift cable cavity and water is being pushed up the cable!
If the shift shaft bushing was bad it would allow water to enter the cavity and cause corrosion problems but it wouldn't have the pressure to get pushed up that high!
