twincities
Thread starter- Joined
- Nov 2, 2009
- 11
I was draining carbs before winter (without a manual & without ever owning an outboard)... 1989 115 2 stroke yamaha
1. Are the drain screws on the side of each carb (small brass and slotted) rather than on the bottom?
I took these out to drain the carb bowls and found that the ones on the lower two carbs were very difficult to access... had to link together a ridiculous amount of extensions and u-joints to get to them...
2. When I did remove them I found they had a small metal washer rather than an O-ring (others mentioned them having an O-ring) is this correct?
3. Are there any products available to use in place of the screws? e.g. Does anyone know of a small Schrader valve or something to put there?
4. Lastly, does the silencer cover need a new gasket from yamaha (it was missing)/is the yamaha gasket reusable of self adhesive and could I just use RTV instead?
thanks
thanks
