i_build
Thread starter- Joined
- Apr 24, 2005
- 164
Just pulled the outdrive because I had clunking noise when turned to extreme left or right and was getting clicking when sustained @> 3k rpm under load... the bellows was flooded with water.
The odd thing is that there is no play on the u joints, no noise when I spin the gimble and the alignment tool slips right in.
Is the best bet right now to replace the ujoints and gimble bearing or lube it up and put in a new bellows?
I'm assuming that since it was that flooded with water that maybe the cursory tests arent revealing the true problem and i should just replace everything (u-joints bellows and gimble bearing).
The lube in the drive was like new (not milky at all).
Please advise. I can get pics if needed.
