The Tach. on my 1998 Fast strike only reads in the low rpm's. It then cuts out at higher speeds. I have been doing some research and tested the amp output between red lead on Rec/Reg. and selinoide. I'm getting a reading of 2.7-3.2 amps output. Obviously this is a low output. I think I should be around 10 amps. Is this a correct way of troubleshooting the Reg/Rec. on this outboard. I recently replaced the powerpack. Boat is running but with this Tach issue I don't want to take a chance and fry another powerpack.
