Carb Question
Amy-Lynn
Maybe someone can help and thankyou for your help in advance ... When i first start boat it starts normal and it idles around 800 fine,and i leave the dock and run out 30 min i can shut down and restart right away if i want but if i let sit for 10 min or longer it takes like maybe 40sec dont no presice but it should just crank over and run lol ,so i am thinking its the choke and going to check that out but wanted to see what you guys thought.
The motor is a 1990 mercruiser with rochester 2 barrel carb alfa 1 outdrive..
Just put head gaskets in 2 weeks ago and rebuilt the carb..
OTHER THEN MY STARTING PROBLEM WHEN IM OUT IN THE WATER THE BOAT RUNS GREAT
jtybt
Re: Carb Question
Choke adjustment sounds like a good start.
Amy-Lynn
Re: Carb Question
Thanks ,was thinking that just wanted to get someone else opinion..
Amy-Lynn
Re: Carb Question
Any other ideas are always welcome ill check em all if i havent ..
Re: Carb Question
Ayuh,... It's either the Choke, or possibly Carb Adjustments done in the rebuild...
I'd start with the Choke...
Gary H NC
Re: Carb Question
Just for fun give it one pump of the throttle then try to start it.
I had one that i adjusted on for days after a rebuild and that was the only way it would start when warm.
I agree the choke should be checked too.
Alpheus
Re: Carb Question
If your choke does not fix the problem have your carb checked to see if your float is stuck,soaked(heavy), or the plugs on the bottom of your float bowl are leaking.
Amy-Lynn
Re: Carb Question
THe huricane is moving up the coast so weather has been bad havent had a chance to look at it but as soon as i do ill post ..thanks for the imputs tho
Alpheus
Re: Carb Question
Im in Norfolk,Va. Everything is under water here. It sucks. Be prepared...
