storedaddy
Thread starter- Joined
- Oct 26, 2009
- 18
trouble shooting a 1979 johnson 15hp thank will not start. took off plug boots and it has splitfire plugs. I have read several times here to only use recommended plugs. how much damage could these plugs have done to the motor? could this be the reason for the no start? no compression tester on hand I will have to get one tomorrow. on with the trouble shoot. the plugs do spark, pull the fuel lever severl times and I can see fuel comming out of the front of the carb not alot but enough to be seen (normal?). what next. obviously compression check
