Pull the plugs and give the cylinders a quick shot of storage spray while you rotate the motor slowly, drain the carbs of residual fuel to prevent varnish formation and give her a shot of storage spray through them while you hold the throttle wide open. Change the lower end oil and remove the prop to extract any fishing line that may have accumulated behind it which might cut the prop shaft seal next year when you start her up again.
Enjoy the winter, content you have her stored safely.![]()
