what to do when your boat sinks?
Azlo
Have you guys had your starcraft stranded in the middle of the lake. What to do when your boat sinks? WHo do u call? U guys carry a inflatable?
Pugetsound
Re: what to do when your boat sinks?
OK It is called A PFD and it is inflatable. Do you know how much space a raft would use.?
Kainon
Keeping a sealable plastic bag on board with some emergency stuff is a no-brainer I think.
Captmills
I guess the big question is why it sank HMMMM:confused:
Azlo
in a state lake who do u call 911? I guess u would need gps to give cordinates out? I know about having your stuff in a plaztic bag, like your cell etc.
Pugetsound
B W R thats no bigger than a seat cushion. For four????. .Inflatable, for all ,is more practical and gives you use of your hands. I never go out on a long trip without mine on. and I was a good swimmer.
Azlo
My tin hasnt sank but i have noticed that it crosses my mind alot. When i launch mine around june i want to be prepaired. Im just gonna stuff my hull with foam :redface:
BWR1953
Yup, liferafts can be stowed very small and come in all kinds of sizes with various amenities. No reason to go offshore without one really. Sitting ON the water beats being IN the water any day!
Here's one from right here on iboats... many such are available.
http://www.iboats.com/Coastal_Compa...5454249--**********.169123291--view_id.366493
starcrafter65
Can I ask a question? What good is the foam under the floor? I have a 18' Holiday that probably weighs 1500 pounds with the Hull+Motor+Outdrive.
The average cubic foot weight of boat is probably around 325 pounds pcf - water is 60 - delta is 250. So water weight is 250/325 *1500 = 1150 pounds/60 = 20 cubic feet water to displace to float.
Each piece of extruded displaces 2.66 cubic feet - so you need 8 pieces of extruded to stuff under my float to float the boat.
Not sure if this is possible!!!
fishinpa
from their advertisement page .
Coastal Compact is not recommended for offshore use
fish
BWR1953
fish
That was just a quickly found example... there ARE others, which are also small. And getting a solid definition of "offshore" is problematic as well. :D
Pugetsound
IMHO If ones main concern in boating is -it may sink ,( which is very rare ) then they should consider staying on land
ruckerra
I got a '47 Johnson TD-20 and a kitchen table. I think I'm going to try that one. Just gotta figure out the beer holder issue.:D
