longstand
Thread starter- Joined
- May 2, 2009
- 293
Jezzz.. iam having problem with tilt again.. i just barely got the new tilt motor to bring up the sterndrive and its not working anymore. again. ARGG
I have put all the ELBOW. the Riser. Exhaust manifold. but i made sure the TIlt was working. before i put everything back..
this is what i have been testing..
I have twin engine.. i connected both the ground from both engine. i made sure i grind all the metal so it will be shiny to get good contact. which mean i have good ground..
I made sure the TiLT wire is shiny to get good contact.. i replace the fuse so i know its getting electricity to the solenoid to power the tilt and the TRIM. and also check if there is 12V power into the solenoid for the trim and tilt to work and there is power..
i trim up and down it work.. i TIlt UP or DOWN. just Click.
so i try something new.. weird one too..
i remove the main ground which connected both engine to the battery negative. i got a jumper cable and connected the negatve from the battery to the TILT ground. and it work. but. if i connected both engine ground the tilt will not move even if the jumper cable is connected directly from the battery to the tilt Ground it self..
this tilt is the only thing is holding me back.. everthing els is finish. the carburator. everything. i even finish painting the engine so it will not rush..
iam lost.. I need expert advise..
Note...
I grind every terminal shiny.
I pack the Clutch and worm gear with Greese.
I made sure i have gasket so the clutch has room for play and not get stock..
Battery is FULLY CHARGE. almost 13 VOLT really really charge..
Note...
