TBSLawnEngine
Thread starter- Joined
- May 25, 2009
- 21
I have a Merc 150 blackmax on my bass boat and am having trouble getting full power out of the engine. It alwasy starts up with little to no problem and revs up quickly and to full power when I have the throttle in the warm up position...prop not engaged. When I engage the prop it will drive around fun put when I put the throttle down to take off it bogs at times and I can sometimes get it to take off with a little moving around throttle and suddenly it takes off. I can run it at full speed accross the water for a min or so and it seems to loose power and I have to pull the throttle back or it will die. After it dies I can get it to start right back up and it will act the same again. I'm a little stumped and am not sure where to procede. I thought it was a cable or carb problem but it doesn't explain why it idles right up with the prop not engaged. Also I don't understand how it can suddenly come to life and take off run like a champ and suddenly loose power. Ideas?
