75johnsonguy
Thread starter- Joined
- Nov 14, 2009
- 6
The lower unit is not an electronic. The motor runs but I removed the drain screw from the lower unit to look for water to drain out and it did. I decided it would be best to fix that problem before running it to much thanks to the advise posted in this forum. I tried putting the shifter in gear by moving the lever at the motor. In reverse the prop grabs but in forward it slips. Any advice would be great thank you everyone.
