Re: Yamaha 225hp 2str Crank Position Sensor test
I am testing the CPS because I get 0 RPM on the tach while the engine is running, I checked electrical connections to the tach, it looks OK.
I did not use the motor since +/-4 years when troubles started in fact, but I started it at least once a year, to summarize the engine only started when yellow cable to bypass the computer was disconnected, then starting it like this , stopping it and reconnecting the cable, the engine started on "normal" circuit and I had the RPM information.
This year, it appeared impossible to start it on the normal circuit, started only when yellow cable disconnected. I decided to check everything on the engine, to make it work correctly and to correct all the sxxt mecanos here made on it (they removed thermostat, made me change stator, ignition coils, etc, etc, then said the CDI/computer had to be changed, etc)
I know what the cps does but frankly speaking I don't really get a few things, now the engine starts whether the yellow cable is connected or not, don't know why exactly, don't really see the relation with other things I corrected, but I think the computer is not operating (based on posts on this forum, I checked that correct voltage output was provided to the computer), I suspected thermo-sensor but it works (not in the range of seloc specs, but as you say it's not reliable), so I suspect the cps, and if it is not him then maybe the computer is dead (but would be a bit surprising because I have two CDIs, and same behaviour with the two)
Or maybe I am completely wrong and could be something else, sorry, I don't see logical relations in what I am describing but that's the situation and I am about sure the computer does not operate and/or is bypassed
