Xesvuli420
Thread starter- Joined
- Sep 20, 2009
- 144
1987 Dixie Bandit
3.0L OMC/ Cobra IO
140hp
WOT Range 4200-4600rpm
My used boat came with a 13.25x3x17p Prop. It was really bad UNDERpropped. I could only get 3/4 thru the throttle before I was at my MAX WOT range.
IF I was to push it to see what RPM the boat would hit with that prop, It would most likely be around 5200-5600
SO, I ordered a 13x3x21p prop to bring d
own the RPM range, and boy did it. Now at WOT I don't even hit 4000rpm unless the water is perfectly still, and I am going STRAIT!
Here are my findings...
13.25x3x17 = >5100rpm, 34mph top GPS speed (Prop from previous owner)
12.8x4x17 = >5100rpm, 32mph top GPS speed (New Ski Prop)
13x3x21 = 4000 max RPM, 38mph GPS speed (Speed Prop)
My question...
I assume that now I need to go to a 19p prop to hit the "desired" WOT range, but if I do will I lose or gain MPH? To me it seems that if now I am at MAX RPM @ 4000, and my "power" is created from 4200-4600rpm, then I should have more top speed if I do go down a size.
I need to decide what to do to get the vessel in PEAK operating conditions, So any help, advice, or testimonials would be greatly appreciated!
Thanks guys
3.0L OMC/ Cobra IO
140hp
My question...
Thanks guys
