When I first bought the boat I took it out for a fishing trip, drove it for 15-20 min and shut the engines off to fish. Tried to start it and the port engine would not start. Took it to the Suzuki repair shop and they replace the ignition switch and it started up again. Took it out to fish afterwards and after running it again for 10 min, I stopped the engines and tried to restart it and the port engine would not start. Took it back to the shop, they told me it was the CDI, which I proved them wrong by switching the CDI from the starboard engine to the port engine and then the port engine to the starboard engine. No difference so I took it back to the repair shop, then told me it was the stator, had that replace, it started up fine so I took it out fishing again and after running it for a few hours of trolling I decided to stop it and see if it will start up again. To my disappointment, the port engine would not start up? Now it is back at the shop again.
Is there something that could be causing the engine not to start after you run the engine for a while? The same routine each time. I replaced something, it would start up fine. I would run the engine, stop it then it would not start up again.....Strange that after each part was replaced the repair shop would test start it several times and so did I after picking it up with no issues. It is not until I take it out in the water and run it for a while that the issue returns. The engine cranks but does not want to start.
thanks for your help.....
