Re: In-dash speedometer troubleshooting
Do water pressure gauges have water flow all the way to the gauge? I always thought they did, but now that Silvertip mentions it, it seems like there would need to be another line dumping the water somwhere.
Is it the same principle with water pressure gauges, the water from the engine compresses the air in the tube and gives you a water pressure reading?
32backnine....Take a look on the bottom of the pitot (L-fitting) and there should be a little metal ball type looking thing, clean that whole area off, and then take your compressed air and blow backwards from where you take the hose off, so that you are blowing back out if the botom of the pitot (L-fitting).
